LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   nitto's on the rear? (https://ls1tech.com/forums/gears-axles/415642-nittos-rear.html)
blackbird-TA Nov 28, 2005 06:03 PM
iv got a 01 blackbird with a bout 340/350rwhp with 315/35/17 nitto dr's will my rear be safe on the street.. and a nother thing when some of you guys snap your axel was it on the street or strip?
Viper Nov 28, 2005 06:25 PM
I'm at 432/405 with nittos, doing fine.
00tals1 Nov 28, 2005 08:21 PM
VIPER what precautions have you took to prevent breaking your rear?
CATCH ME Nov 28, 2005 08:31 PM
auto or M6? its a toss up with the M6, it might last...it might break
camaross305 Nov 28, 2005 09:29 PM
i have the same ?...im at about 340 rwhp and im interested in a lil stickier of a tire but im an m6 and dont have the money till summer for a 9 inch should i just stick with street tires?
blackbird-TA Nov 28, 2005 10:29 PM
yes im also a m6 im really wanting to slap on some nitto's.. they look great and hook great.. and i just really think nitto's great lol
Steve Burger Nov 28, 2005 10:49 PM
I have run them for years on the street. They are fine. Slow down a little in the rain and you'll be OK. I run ET Drags at the track. Nittos won't hold.
Oh to avoid breeaking axels upgrade to a 12 bolt or 9"
Croaker Nov 29, 2005 06:38 AM
I think that was kind of the point of the thread - not a tire review, but a "will my 10-bolt survive if I run Nittos on the street".
I personally wouldn't risk it, especially if your car is a daily driver. :nono:
I make around the same power and I fear for my 10-bolt even on street tires.
1badA3Z Dec 4, 2005 07:01 PM
nittos will break a 10 bolt,get a 12 or 9,and be carefull in the rain on nittos,the can get tricky
Krab Dec 5, 2005 12:03 AM
You'll be fine on the street with some nittos on back. Just don't heat them up and do a 5K rpm clutch dump and you'll be ok. I've been running on nittos (second set now) for a little over two years now and haven't broken anything on the street yet. At the track on BFG's is another story...
dailydriver Dec 5, 2005 03:14 PM
My Nittos heat cycled/hardened up so much from daily use that I think I'd have a better chance of breaking my 10 bolt on a good street tire, especially in the cold weather! This is even with weaker 4.10 gears. You should be fine, as long as you don't heat them up much in the street, as stated above.
TAwananbe Dec 7, 2005 11:04 PM
I have the 315 nittos witha 12 bolt and hook well............well, I pretty much have every mod available int the Drivetrain/suspension.
I will roast stock tires......had to go with the DRs for traction.....wet is kinda bad though.
© 2026 MH Sub I, LLC dba Internet Brands
