slicks??? what do i need to do
Old 12-08-2005, 12:12 AM
2002LS1Z28's Avatar
Default slicks??? what do i need to do
if i plan on using slicks and a 125 shot.....what do i need to do so i dont snap the rear end... i hear that any one who uses slicks on a stock rear end breaks it???
Old 12-08-2005, 01:45 AM
ls1408cp's Avatar
10bolt and slicks are sure to break your rear end only fix 12bolt or 9inch
Old 12-08-2005, 08:43 AM
LS1TECH Sponsor
Steve Burger's Avatar
12 bolt or 9" and a better drive shaft. Add a DS saftey loop as well. It's required with slicks and you be real happy you have it if needed. I know this first hand.
Old 12-09-2005, 06:46 AM
EPP
EPP's Avatar
Moser 12 bolt. Bob
Old 12-09-2005, 02:35 PM
trigger1's Avatar
I would say prayer is a good first step. If that doesn't work I would look into a 9inch, Driveshaft and a D/S loop like mentioned above.
Old 12-09-2005, 08:09 PM
s346k's Avatar
m6 + 10 bolt + slicks = excellent opportunity to install a 9"
if you're spraying out of the hole on top of that...i will pray that you don't procreate
Old 12-10-2005, 10:40 PM
as35thss's Avatar
Get a 12 bolt or 9in. Don't do that to your 10 bolt. If you do, make sure you have a drive shaft loop. You are going to break the rear or the drive shaft. Trust me.
Old 12-11-2005, 12:11 AM
blue01ta's Avatar
You have to have a loop to run slicks at the track anyhow.
Old 12-16-2005, 11:17 AM
pasbonsimon's Avatar
my 10 bolt went boom on street tires - never even had drag radials
Old 12-16-2005, 01:23 PM
Ace$nyper's Avatar
Loop and shaft at very least.
Spending some time asking your deity for luck isn't a bad investment of time either.
Some people have luck with 10 bolts. I myself rather not gamble start saving up for a 9".
