Help with Eaton LS
Old Dec 18, 2005 | 08:11 PM
Jordan S.'s Avatar
Default HELP! Rod wont go in Eaton posi
I'm putting my rear end back together and came onto a problem.
I have my axles in and the clips in them and the axles pulled outward. I went to put the rod back (one in the center that holes the axles in place) into my EATON limited slip and the rod will not go in because the center part with the springs has moved downward and the holes do not line up with holes on the housing?
How do I line them back up to put the rod back in?
Old Dec 18, 2005 | 08:13 PM
Jordan S.'s Avatar
My only guess is hold one axle and rotate the other but I dont have anyone here to hold it for me.
