Stock Rear End Swap / Need Help, Advise Please...
Hi,
I am swapping another stock rear end into my 98 TA, my question is this... My car does not have traction control, the rear end that I am putting in came from a car that had traction control, is there something I should know before I do this? Is there a special connector required for the ABS? Any help would be appreciated.
Thanks
Brian
Thanks
Brian
Re: Stock Rear End Swap / Need Help, Advise Please...
The non-TCS cars use a three channel ABS setup with the reluctor on the differential I believe. The TCS cars use a four channel setup with reluctors located at the end of each axle.
Thanks Ragtop 99 for bringing it to the top and also thanks Chris for the reply <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I just looked at my rear end and it does have the single sensor located at the top of the differential. I do not have the other rear end yet so I do not know what the TCS set up looks like. Anyone got any pic's?
I'm not even sure I can do this now. Is there anyone out there that has switched from a non TCS car to a TCS car? Anyone?
Thanks
Brian
Thanks
Brian
