Building a rear end (9")...???
I have access to a basically free 9" out of an old 70's Ford, with drum brakes. I can get another complete 10 bolt with brakes, etc...
Is there a link to "building" a 9" with 4 ch. abs anywhere? I think I could pull it off!
Has anyone done it here? Talk to me about it...
From what I understand it's a big job and you have to be a good welder to get the springs perches and torque arm and LCA brackets and shock brackets in the right place. The pumpkins from back in the '70's were a gray cast iron not as strong as the nodular iron used today. The only positive I can see is price vs alot of negatives.
Its difficult not impossible..You need special tools that will cost more than buying a Moser... there are techniques that are used to maintain axel centerline after all welding is complete this has been covered 1000 times in this section please use the search feature or check out the rear end FAQ ...
Good point on the strength and weight.
uhhhhh... you just told another person to use the search feature as well... the most useful thing was EPP saying that it can warp when welding in the sticky.
So saying that I can jig it up, has anyone here done this, or made a write-up on it? I have not seen one, have you? I'm just tossing some ideas around before I blow up my rear end...
