will s10 rear fit camaro?
my buddy has a 98s10 with a 12 bolt in it and he was turning the truck into a drag truck but now he changed his mind just wondering if the 12 bolt will bolt right in without any mod or will i have to change the mounting spots on it before i put it in my camaro
S10's never came with 12 bolts so there is no way to answer that, it depends on how they put it in. The answer is no for sure, there is no reason it would have a torque arm mount. And if it was narrowed down to the stock S10 width of 55" it's going to be way too narrow.
it was narrowed when he bought it about 2yrs ago. he bought the truck down south it already had the 12bolt in it and i know the s10 never came with a 12bolt.
I figured you knew S10's never came with 12 bolts. The point is to get a 12 bolt in one it needs to be narrowed, then what else was done, it makes no sense to narrow it to stock width and use stock size tires. So other question pop up like how much was it narrowed? was it four linked? ETC.
Bottom line is this....if your car is stock no it won't even come close to working.
If your car is tubbed and four linked then maybe but highly unlikely.
In fact without even knowing anything else I can say it won't work. It won't even come close to working.
