Ohh shit..... Im fu*ked
Ohh ****..... Im fu*ked
I was just driving home and I hear a pop in the rear of my car. And I start to accelerate and the whole car was shaking, I could feel it in my foot also. I think I just blew out my 4:10's....
is all the differential fluid going to drain out? if so im gonna need to buy new stuff, so what should i buy? Also what does it do when your gears go out so that way I can make sure its for sure my gears
yeah the fluid will drain out.
and what will it look like when gears go out?
a big chunk of metal missing from the ring gear, or pinion, though usually ring.
sounds like you shouldnt be worried about getting more fluid considering the gears are toast.
https://ls1tech.com/forums/showthrea...ht=broken+gear
there are pics of various gears and rearends that have given up.
probably broke the carrier since it's still going down the road OK other than the shake. The gears will be gone soon if you don't shut it down. Then again, with the carrier shattered/cracked the gears are junk anyway. Time for an Auburn pro carrier and a new set of 4.10's!!!
Originally Posted by RaNsOm
eh, sometimes. I broke my 4.33's launching at the track and actually made it all the way down the 1/4 mile, turned around, down the return lane and into the pits with 5-6 teeth missing off the ring gear and 2-3 off the pinion gear. If you break them while your moving, if you keep moving you'll be able to drive it, it'll just be really really bad sounding, lol.
i feel for you man...
i torched my 4.10s....and when i drove it home ended up lockin up synchros 1 and 2. at a dead stop i could shift into all gears, once i was rolling, could not get back in them til a dead stop again. so, at all costs do not drive the car til the new gears are in.....
I was lucky when my 4.10's went ... the car actually made it home (about ~20 miles) under its own steam, and all that went were 2 teeth off the pinion. That was after a couple hard days on a road course, mind you!
...then ~2 weeks later and 2nd gear started slipping, so just last night I finished up the A4 --> M6 swap!!
k im just going back to the stock gears for now.. do i need to get new bearings and shims? is this necessary? or can i just put the stock gears back in and take the broken 4 10's out?
When my 4.10's went, I put back the original 3.23's to that carrier. I cleaned and inspected all the bearings really well, and they all looked good still, so I re-used them. The shims can be cleaned and re-used without a problem, but they may not be the right thickness you need anyway to go back to the stock gears.
