- - 3.73's on my 2000 SS
(https://ls1tech.com/forums/gears-axles/561919-3-73s-my-2000-ss.html)
dfreeman2386
Aug 19, 2006 05:21 PM
does a three series carrier work on a camaro ss automatic with traction control or is it a two series?
fast377
Aug 20, 2006 11:06 AM
depends on what gear ratio you have factory
keliente
Aug 20, 2006 11:49 AM
Series depends on gear, channel depends on abs/tcs options.
2 series = 2.73 cars. 3 series = 3.23, 3.42 cars. The only time series comes into play is when you are trying to order new gears for your car. If you want 3.73s and your car came with 2.73s, you need 2 series gears. If you want 3.73s and your car came with 3.23s, you need 3 series gears.
Putting a three channel rear end into a four channel car requires you adding reluctor rings & traction control sensors to both axles.
dfreeman2386
Aug 20, 2006 10:10 PM
thanks for the info, very helpful
BJSS25
Aug 21, 2006 08:31 PM
Go ahead and put 4.10's in it, I went from 3.23 to 4.10. I'm glad I did it made a huge difference.
Josh2006
Aug 21, 2006 08:49 PM
you have an SS so you have 3.23 if its an Auto and 3.42 if it is a M6 so either way its a 3 carrier
