LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   Won't Shift Into 3rd At WOT Help!! (https://ls1tech.com/forums/gears-axles/5964-wont-shift-into-3rd-wot-help.html)
XAntivenomX Jul 13, 2002 02:06 AM
Sometimes the car will shift into OD as soon as possible and will stay there unless manually downshifted, but then will go back to OD after a second or two. Shifting is also kinda erratic(sp?) sometimes it'll shift very hard, but other times it is very soft and easy. At WOT sometimes it won't shift into 2nd, but will not shift into 3rd or 4th unless I let off for about a half a second. I am getting a TPS code, an MAF code, and a tranny code. We(MTI and I) were thinking it was a bad TPS, but I replaced it with a brand new one, and the problem persists. I have reset the PCM a couple times and that didn't help either.
I'm thinking maybe it's the MAF?
Any ideas?
TomQ Jul 13, 2002 06:45 PM
Re: Won't Shift Into 3rd At WOT Help!!
change your shift points, if u installed your TC
nothing else to add
<small>[ July 13, 2002, 06:46 PM: Message edited by: TomQ ]</small>
XAntivenomX Jul 13, 2002 08:57 PM
MTI changed the shift points and the rev limiter when they did the tuning after the cam. The converter has not been put in yet. It is not just bouncing off the rev limiter, I am getting codes.
Maybe this should be moved to the Computer Diagnostics Board.
<small>[ July 13, 2002, 09:50 PM: Message edited by: Anti Venom ]</small>
XAntivenomX Jul 14, 2002 03:27 PM
ttt
Ragtop 99 Jul 15, 2002 09:06 AM
I'll leave this topic here for now. If you are getting codes, you can add them to this post and start a topic on those codes in Computer.
Have you talked to MTI about this? Try putting your stock MAF on and see if that helps.
XAntivenomX Jul 15, 2002 11:39 AM
Haven't had a chance to talk to MTI yet. Will call them this afternoon. The car is at a local shop getting the converter, shift kit,etc put in. They are gonna check it out while its there.
I don't have another MAF, I just have new ends.
Ragtop 99 Jul 15, 2002 02:02 PM
Check with MTI and make sure they didn't increase your shift firmness. You don't want to add extra computer driven line pressure on top of a shift kit.
XAntivenomX Jul 16, 2002 12:28 AM
Thanks for the info, Ragtop. I will definitely talk to them about that.
Which would be better, the computer controlled firmer shifts or a shift kit?
I talked to Jeff@MTI today, and he said that this IS my TPS so I need to check the wiring and replace it. The local shop told me it had a TPS code, and a couple O2 sensor codes(open headers at the moment), which backs up MTI's thoughts.
The local shop doesn't want to mess with it much until it has exhaust on it, they said it was too loud and didn't want to get a ticket test driving it. So I should have the car back tomorrow and then I'll be able to check out the wiring.
Ragtop 99 Jul 16, 2002 08:25 AM
A properly installed shift kit is the better way to increase shift firmness.
XAntivenomX Jul 16, 2002 01:23 PM
thanks for the info, I guess I need to get LS1 edit or something to fix that stuff if they messed with it so I can put in the shift kit.
XAntivenomX Jul 22, 2002 12:57 AM
Here is an update
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=001820
© 2026 MH Sub I, LLC dba Internet Brands
