4.10's being installed as we speak...
just have a few questions....
1). I got Motive 4.10's with a Ratech deluxe kit. WHat should the break in period be?
2). I also have the HPP3. Can i use that to tune for the gears?
3). Someone in another thread said that first gear becomes useless in a m6? what does that mean?
thanks!
thanks!
thanks!
thanks!
2)yes you can
3)he was saying that first gear is too short to use, since the gears will not take as long to get to your shift points... yes 1st gear is very short with 4.10s, but there is no need to stop using it.
Originally Posted by 2000TransAmWS6
1)run it up and down in the gears a couple time, making sure to leave it in gear as you slow down so that it'll make its pattern on the back side of the gear also... people will tell you different things to do, but thats all i've ever done... ask the person thats installing them and see what he says
2)yes you can
2)yes you can
