Rear on the way out?
Old Nov 29, 2006 | 04:40 PM
tclelland's Avatar
Default Rear on the way out?
On a moderately hard launch I hear a bang from the rear of the car. Is it time for me to save for a 12 bolt? I am leaking a little fluid and I'm not sure if there is a way for me to check the level?
Old Nov 29, 2006 | 04:44 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Could be wheel hop...could also be your transmission mount letting the trans bang the cross member (but you'd probably know if it was that). It doesn't necessarily mean your 10-bolt is on its way out, but if it is wheel hop, any rear end wouldn't like that.
As for checking the level, GM included an idiot-proof fill plug on the passenger side of the pumpkin. Take it out (on level ground), and see if anything comes out (nothing will most likely). Then add a little until it does...that'll top it off.
Old Nov 29, 2006 | 05:24 PM
Revelation Z28's Avatar
but its in an idiot area. cant fill it worth a **** with anything. need a pump. even the little bottles of the LSD additive.
TA cover FTW
Old Nov 30, 2006 | 11:04 AM
MeentSS02's Avatar
TA cover FTW
Very true
Honestly, I've never used that plug to fill it since I got a TA cover the first time I changed the fluid.
