9inch HELP!!!!!!! Hey guys.Installing a 9inch ford Moser in a 98 trans am.Having alot of trouble fitting the BMR torque-arm to the housing mount.Anyone else have these problems?What other torque arms are you all useing?Any help much appreciated!Thanks,Lyle |
Is the rear end jacked up? If so try holding the car up elsewhere and letting the rear hang down, thats what ive done to get it in easy. |
Originally Posted by nahasapeemapetalon Is the rear end jacked up? If so try holding the car up elsewhere and letting the rear hang down, thats what ive done to get it in easy. |
Just grind off what you have to. We don't normally have any problems fitting torque arms on the Moser 9 inch rears, but occasionally it does have a slight interference. Bob |
Originally Posted by Exotic Performance Plus Just grind off what you have to. We don't normally have any problems fitting torque arms on the Moser 9 inch rears, but occasionally it does have a slight interference. Bob |
Now that the torque arm fits on the moser housing,it looks like the rearend sits 1.5 inches back too far with one control arm on.the other control arm is 1.5 inches away from hole.How can this be?Is the torque arm too long?why?It fit on the old stock rearend no problem.Moser housing is supposed to be direct replacement.The control arms are also BMR.Has anyone else ran into this problem? |
running a spohn t/a via the crossmember on the m6 and just did a swap on my 35th with a random tech t/a.no problems here. |
Originally Posted by blue83z Now that the torque arm fits on the moser housing,it looks like the rearend sits 1.5 inches back too far with one control arm on.the other control arm is 1.5 inches away from hole.How can this be?Is the torque arm too long?why?It fit on the old stock rearend no problem.Moser housing is supposed to be direct replacement.The control arms are also BMR.Has anyone else ran into this problem? |
I will post some pics as soon as I can.Thanks guys! |
Had to loosen torque arm up front.Slid forward.Now its good.Thanks for help guys.Lyle |
I'm glad to see you got it moved forward. Bob |
© 2024 MH Sub I, LLC dba Internet Brands
