How much ET am I losing with my 4.30 gear?
My mods are Hooker LT's with ORY, TP4400, Moser 12-bolt with 4.30, 28x9x15 Hoosier drags
My best motor pass has been 12.30 @ 109 with a 1.62 60' and a raceweight of 3470.
Is the 4.30 gear with the 28's hurting my ET?
Thanks,
Jeffrey
Thanks,
Jeffrey
Look at what RPM you are crossing the traps at. If you are within a couple hundred rpm's of your rev limiter then you are doing good.
I cross the traps at right about 6000, so it's almost optimal as far as RPM.
I was just wondering if I would run better with a 3.90 26" combo instead of 4.30 28"
I guess I'll leave it alone for now.
Thanks for the info.
Jeffrey
Jeffrey
