What fluids when installing Gm 4.10's in stock 10 bolt
I searched, but and know what gm suggests but not 100% sure on what i want to do yet.
Im going to install the gm 4.10s in my 98 trans am, m6 this weekend probably, and want to know if i should go with the 75w90 that gm suggests with the 1 bottle of the gm limited slip additive?
Should i go with a synthetic fluid like mobile 1, or royal purple or something?
What would be the benefit of going with the royal purple 85w140 that speed inc suggests? I really have no idea what fluids i need to buy, so any help would be great. Ive never done a gear, but have a mechanic helping me out so shouldn't be to bad. Thanks, Chris
Ps are there any how to's? or things i should know/be aware of before i start the install? Thanks, Chris
Originally Posted by Sideways240sx
IWhat would be the benefit of going with the royal purple 85w140 that speed inc suggests?
Well, lets start off with better temperature stability, lower running temperatures... and about a 50% increase in shockload resistance. The only thing I use 75/90 or straight 90wt in is front ends (4x4) and stock applications. Performance use damn near dictates that you use a better lubericant with better shockloading properties. I dont care if the engineers spent eleventybillion dollars on research and development... and the fact that they put that number in the manual just goes to show you the massive oversight on their behalf. I mean afterall... those same engineers did put a 7.5" mini truck differential into a performance platform that was clearly underrated to begin with.
On the subject of lubericant... I however, would not use a full synthetic. In fact if it were up to me, I would use a straight weight 140 that is parrifin based. The Auburn will also benifit greatly from its use as well.
how do i know if the car has an auburn? im trying to look in the faq, but dont see anything. Thanks, Chris
you dont have to pull the cover if you jack the back of the car up
https://ls1tech.com/forums/gears-axles/747040-did-everyone-get-stock-posi.html
Unless you, or the previous owner put something else in there, you have an Auburn. I most definitely would NOT use synthetic gear oil with an Auburn diff!
Originally Posted by chicane
I dont run it straight... but as an additive its great.
chicane; I believe he's referring to the actual Lucas mineral based gear oil, like I'm using right now (in 85W-140). It's also one of the "default" gear oil choices you've suggested in the past, in a pinch, if one cannot get Shaeffer's 209 or Torco RGO soon enough for their change.
Originally Posted by Grn4fbody
In ANY rear end i use Lucus fluid, we use it in the Semi's at work and all, but you do need the additive for the posi
Sorry i cant type and or spell
