9" rear launching technique..
Just wondering how you guys launch your cars with a 9" diff..........
I just put mine on and still breaking it in so I havnt had a chance to practice.
I'm going to be running at the track with a set of Mickey Thompsons... and have an LS7 clutch......
What would you recommend?
Dropping the clutch at 6k rpms? Feathering? etc.etc.
thanks
thanks
Originally Posted by Exotic Performance Plus
I would start at 4000 rpm and see how the chassis reacts to it. Bob
Im not too worried about the chasis.... i have sub frame connectors and the other whole 9 yards....
was just curious as to what has worked for others...
funny you ask
i went on et streets bias plys and tried launching i never spun just a hook and bog. i tried 3.5-4k dumps and some slips at aprx 2.5-3k
i had the tires at 20psi.
when i go again im gonna put them a 25 to start with and launch at my peak tq (just got a dyno tune) and it is 4400 and flat lines till 4800 then falls off from their so maby ill try around 5k
i would be nice to cut a good 60 on slicks these 1.9's and i mean high 1.9s are killing me and yes i had some 2.0+ in there to my best was a 1.897 (and that was pre tune ls6 im and tb)
i think a mid 1.7 would be ideal for me
im at 13psi on stock rimmed DOT slicks on a stock 4.10d rear cutting a 1.83 slipping the clutch at 3k, 20+psi is too high, you'll just spin... i just got my moser 9" and whole rear chassis and am planning to use the same stock rimmed DOTs, ill start at a 4k slip and 13psi again, we'll see.
1.50 on a 9" spool with 28" et drags. dumped the clutch at 5k. next time out I will be looking for low to mid 1.4's. By the way t was also 33* outside so it was a little cold.
I also have a 9" and I have been having some serious issues with traction. I tried dumping it at like 1700 and it bogs, so I tried like 2500 and it wheel hops really bad. I have an adjustable torque arm, and it is set at -1.5. Does anybody know what I need to do to fix this problem!? Does it need to be set at a different degree? Do I need the relocation brackets? the best I've run with the 9" is 1.89. ...not to proud lol.
thanks guys!
thanks guys!
Closed Sponsor Account
thanks guys!
thanks guys!
If I was to take a wild guess as to the tires you were running, I would say Nittos...am I right?
Erik
