LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   What with 3.73's? (https://ls1tech.com/forums/gears-axles/786201-what-3-73s.html)
bigdaddy1010 Sep 20, 2007 03:24 PM
What with 3.73's?
What all do I need to buy for changing from 2.73 to 3.73 on my 99 z28? Some local guys said I would need a programmer because my speedo would be off. Is this correct? Or do I just need the gears and an install kit?
keliente Sep 20, 2007 04:54 PM
You'd need to have it reprogrammed for the new gear or the speedo will be off.
You would need an install kit, fluid, etc.
Make sure you are buying 2 series gears.
bigdaddy1010 Sep 20, 2007 07:49 PM
This is an a4 also.
SteveC Sep 21, 2007 09:07 PM
You will need to have the PCM reprogrammed, for it uses the MPH/RPM to correctly shift the auto transmission.
I upgraded to 3.73's and a Y3000 TC, and for the week I had to drive it until tuned, the PCM did not know what the hell was going on, I experienced idle hunt, premature shifts, down shifting at freeway speeds (my personal favorite), and a variety of other malities that were corrected with the dyno tune.
SteveC :)
TA1364 Sep 21, 2007 09:54 PM
How did 373s and a 3000stall do? Im thinking about same thing, just need convincing on DD
SteveC Sep 22, 2007 09:19 AM
It changed the vehicle completly from the stock TC and 3.23 gears, HOWEVER, if I had it to do all over again, I would have gone to a 3600 stall.
SteveC :)
© 2026 MH Sub I, LLC dba Internet Brands
