Reluctor Rings? I see most rearends have the option of new reluctor rings, or use the old ones. Do the ones on the factory 7.5 just unbolt and go onto the new axles?.. If you have your old rearend, is their any reason to use "new rings"? |
I got new ones from Moser when I ordered my axles. They are beefier than stock but I really don't think it matters. You can reuse the stock ones but they need to be pressed onto the axles. I just wanted everything to be new when I swaped out my rearend. |
They can be pressed off and on. If you are on a budget just reuse them since they physically do nothing but create a magnetic field that the VSS picks up at each wheel to determine that one wheel is not spinning faster than the other (thus you have Traction Control). But like Jay said there is no feeling like knowing that everything is brand new. Oh and don't hold me to it but I suppose there could be a reason that the rings would need to be a different size if you are using heavier spline axles but I'm not %100 sure. There are a few driveline sponsors that could clear this up fast for ya... |
What happens if you use the reluctor rings but have a spool? It just always thinks you have traction, and the abs / tc will never engage? Or will you have abs but you wont have traction control? |
Originally Posted by LS1Silverado05
(Post 8687554)
Originally Posted by Jays00ss
(Post 8687589)
You can not run a spool and have traction control. A spool locks your axles together all the time. Traction control needs to regulate speed between both sides. It will not work with a spool. |
ABS will not work right. It will try and bias braking to each wheel. They are locked together and can not bias. With a spool I would ditch ABS and TCS. |
Originally Posted by Steve Burger
(Post 8688546)
so if you get a 12bolt or 9inch ect and have deleted the abs and traction control do you need the reluctor rings at all? im getting ready to order a rear and i am not sure what i need to order on it. i want a true bolt on rear so i just want to order everything i need when i order the rear |
If you have access to a good torch, you just need to heat up the rings while they are on the old axles. With a medium prybar, pry them up side to side. They should come off with minor effort. Grab them with channel locks, heat them up a bit more, and they will literally drop onto the new axle. You may need to tap them home with a light hammer. Its best to have the new and old axle standing up side by side with the flanges on the floor. |
Originally Posted by RiskyZ28
(Post 8689222)
© 2024 MH Sub I, LLC dba Internet Brands
