Rear end clunking sound???
I have this clunking sound whenever I hit a bump or uneven surface in the road. Its on the driver's side. But, when I jack the car up, I can't find anything loose or whatever.Any ideas??
Re: Rear end clunking sound???
Its not the hatch, I can open the door when drving slowly and hear a loud rattle when I hit a bump. Sounds like a really loose dust shield or something...it's driving me nuts
I had the same problem a while back. Mine only happened intermittently though, not every time. It would also happen sometimes when I would do something as simple as close the door. Had me stumped for the longest time. All I know is that when I adjusted the coil springs to fix what I thought to be an unrelated problem, the clunking went away. So you might wanna try that.
I may give that a try..I was thinking that it might also be the heat shield under the gas tank. Its not doing it every time, just once in a while..
