28 or 31 spline axles?
Old 03-18-2008, 10:33 AM
T/AWS666's Avatar
Default 28 or 31 spline axles?
I am looking to buy a moser 9" and was wondering what axles i should go with? 28 or 31? whats the difference/advantages of them?
Old 03-18-2008, 11:29 AM
jmm98LS1's Avatar
More splines = more contact area = stronger axle. Go with 31 spline, they're probably the most common with the 9".
Old 03-18-2008, 11:49 AM
Jays00ss's Avatar
I have 35 splined axles in my 9" but you are limited to either running a Spool or a Detroit Locker.
I elected for the Locker
Old 03-18-2008, 12:41 PM
LS1TECH Sponsor
Steve Burger's Avatar
As the splie count increases, the phyisical diameter of the axle increases. The more splines the thicker and stronger the axle becomes. It also weighs a little more. You can gun drill to reduce the weight and still get the extra strength.
I would go 31 spline. It will be a stronger part and handle more HP. Above 31 spline and the diff choices start to get limited.
