LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   Question bout 4.10's (https://ls1tech.com/forums/gears-axles/8852-question-bout-4-10s.html)
BoneStock Feb 28, 2003 08:15 PM
I have a 2002 WS6. Do I have to go with SLP's paddle kit to install 4.10's. I read something about the SS, Firehawk, and WS6 not having to use this. Is this true? Also would you recommend this gear over a 3.73?
DONAIMIAN Feb 28, 2003 09:17 PM
Re: Question bout 4.10's
Nobody really recomends 4.10's just because. People recomend it depending on your set up. What mods do you have so far.
BoneStock Feb 28, 2003 09:24 PM
I only have a few mods which include filter, lid, and MAF sensor. But at the track I'm hitting the rev limiter in 3rd with 3.42's and 3.73's would just put me shifting into fourth.
2000WhiteZ28 Feb 28, 2003 10:08 PM
If you are planning to use stock tires or 26" drag tires (most common for us F-Bodies) I would stick to 3.73's. You will finish in about the right gear. You need shift tuning to avoid the rev limiter. 4.10's are typically for bigger tires in the back. If you are planning on forced induction (turbo, super, N2O) then I would stick with 3.42's for those really high trap speeds.
WILWAXU Mar 1, 2003 05:04 AM
Moving to Drivetrain section.
WJ SOM SS Mar 1, 2003 11:10 AM
M6 car w/4.10's and 26" tire should be going thru 1/4 mi. traps in 4th at right around 5800 w/stock valvetrain. Use some form of programming to raise rev limiter to 6300--no more. Also, program for the gear change for speedo readings, any tire size changes & you should be good to go....P.S. Don't wait till the limiter hits to shift...6000 works real nice... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> WJ.
© 2026 MH Sub I, LLC dba Internet Brands
