9" users-Should the axels be a tight fit in the diff
Old Mar 22, 2008 | 07:21 AM
n2ocamaro's Avatar
Default 9" users-Should the axels be a tight fit in the diff
I tried to install my axels and they only slide part of the way in the diff easily. Are you supposed to have to tap them in with a mallet or should they slide in all the way by hand until you get the o-ring on the bearing to the housing end. Seems really really tight.
Old Mar 22, 2008 | 07:39 AM
mcflyz28's Avatar
give them a tap till the bearing is flush with the housing or at least close enough to start the backing plate nuts.
Old Mar 22, 2008 | 08:28 AM
linegtdt52's Avatar
tap with rubber mallet
Old Mar 22, 2008 | 08:55 AM
n2ocamaro's Avatar
Thanks. Just wanted to make sure there wasn't a problem.
