has anyone went from 3.23 to 3.73 with a 3000 stall conv
Old 07-27-2003, 09:05 PM
Jalbert's Avatar
Default has anyone went from 3.23 to 3.73 with a 3000 stall conv
is it worth it and will there be an et gain.
Old 07-28-2003, 01:57 PM
BLB02TA's Avatar
Default Re: has anyone went from 3.23 to 3.73 with a 3000 stall conv
If you can let me know I what you find out, that is what I was planning for my car.
Old 07-28-2003, 07:44 PM
Ragtop 99's Avatar
Once you have a high stall converter (atleast 2800) and proper shift points, the gains are consistently about .1 and 1 mph on that swap.
Old 07-29-2003, 04:12 AM
4thGENRETARD's Avatar
Ragtop,
How about 3:73 without TC. I drive my car daily and with the heat here I'm sceptical about changing my TC for fear of tranny damage. I've heard that tranny failure is unavoidable with TC change.
Old 07-29-2003, 12:25 PM
Ragtop 99's Avatar
sharky:
What you've heard ("I've heard that tranny failure is unavoidable with TC change") is completely false. A mild low STR stall like a SY 3500 or a TCS 3300 with a 2.0 STR when used with a tranny cooler will not significantly increase your risk of failure. Sure, any mod (e.g. lid, catback, or TC) that increase power through the tranny increases the risk of failure due to the extra torque. However a mild converter is not that big a risk.
A 4000 stall with a 2.5 STR is different, IMO. That can really increase the max torque and the duration of high torque. Even still, bolt-on cars with very high stalls still have a pretty good track record of reliability.
Figure .2 and 2 mph from the switch assuming no TC. By the way, your rear is more likely to develop issues (e.g. whine or gear tooth failure) when you swap gears than your tranny is likely to fail from a mild converter swap.
Old 07-29-2003, 01:44 PM
BLB02TA's Avatar
Is that the 1/4 or 1/8?
Old 07-29-2003, 03:48 PM
Ragtop 99's Avatar
1/4
Probably see most of the gain in the 1/8th
