4.30's too big?
Old Apr 14, 2008 | 07:49 PM
GoodlookinLS1's Avatar
Default 4.30's too big?
thinking of going to 4.30's but dont want to be shifting into fifth in the quarter will i be doing that or no? i have to get a rear end and i already have a huge cam so i was thinking the gears would make it a little more streetable. TIA
Old Apr 14, 2008 | 07:58 PM
EPP's Avatar
EPP
It depends on how high you rev your engine to, your rear tire size, and how much horsepower you are making. Back in '04 my Z28 was at 540 rwhp, had 28" M/T ET's, and 4.10 gears in the Moser 12 bolt. I was on the 6200 rev limiter at the 1000 ft mark in 4th gear. I ran it on out bouncing off the rev limiter. We didn't set it any higher prior to going to the track because the engine had 126,000 miles on it.
My car is the one on the left. Bob
Old Apr 14, 2008 | 08:06 PM
sorry looking to rev to 6500, thinking of a 26" tire, and making about 540 to the wheels
Old Apr 14, 2008 | 08:13 PM
cabel1's Avatar
I turn 6200 through the lights at 116 on 27" tires. On a 4.30 gear
Old Apr 14, 2008 | 08:16 PM
jmm98LS1's Avatar
That's going to be too much gear, you'll be on the limiter at 115mph. Stepping up to a 28" tire would get you 126mph which would be cutting it close.....
Old Apr 14, 2008 | 08:29 PM
Jays00ss's Avatar
4.30's here and absolutely love them. I will run a 26.5" tall tire for the track and will be fine. Takeing my motor to 6500 rpm.
Old Apr 14, 2008 | 08:30 PM
z28misfit's Avatar
I'm running 4.56's, 28" tires and I'm usually around the 6800rpm range or so in 4th.
