help gear pattern?
Old Apr 16, 2008 | 06:08 PM
SLP Firehawk's Avatar
Default help gear pattern?
hey i am installed my gears for the second time this week i messed up the first time and i think i need a new shim for my pinion... anyone care to give some info about what the pattern tells?
these pics are with stock shim and backlash .005
thanks in advance
Old Apr 16, 2008 | 07:51 PM
MIKE02WS6's Avatar
Doesn't look bad on the drive side. Hard to tell on coast. Some one else may have a better eye then me. These pics might help you compare. Here is my set up when I installed mine. I have no noise on drive or coast. They are GM Superior Gears 4:10's with .005 backlash, reused my factory pinion shim.
Drive
Coast
Old Apr 16, 2008 | 09:08 PM
it wined real bad on accel so i took the rear all apart again and am going to change the shim around i think the pinion is to shallow.
Old Apr 16, 2008 | 10:35 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Backlash could be too tight, what di dyou set it at?
Old Apr 17, 2008 | 06:26 AM
Backlash Is At .005
Old Apr 17, 2008 | 06:27 AM
I Also Noticed When I Pulled The Rear Apart Last Night The Preload On The Pinion Became Alot Less Than What I Originally Set It At Why Would That Be?
Old Apr 17, 2008 | 08:05 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Pinion preload lessens with usage(for new bearings).
New bearings that started at a 20 in.lb. preload could drop to/settle in at 5 in.lbs.
Old Apr 17, 2008 | 09:46 AM
They Are The Old Bearings Though
Old Apr 17, 2008 | 12:53 PM
Jawsgear's Avatar
Depth too deep and backlash is too tight.
Jeff
Old Apr 17, 2008 | 01:06 PM
Jeff
OK THATS WHAT I WAS THINKING TO AFTER LOOKED AT THE INSTALL INSTRUCTIONS, DOES TO DEEP MEAN I NEED LESS SHIM? OR MORE SHIM?
Old Apr 17, 2008 | 02:51 PM
Jawsgear's Avatar
less shim
Old Apr 17, 2008 | 03:01 PM
Ok Thanks That Helps Me Alot I'll Try With No Shim And Work From There
Old Apr 17, 2008 | 05:33 PM
Jawsgear's Avatar
Try about a .028" pinion shim and open up backlash to avout .010". That would be my starting point for these gears.
Jeff
Old Apr 17, 2008 | 08:52 PM
sweet thanks
