9" help choosing differential, axles, swaybar
?'s at bottom of this
i have a 02 SS M6 which is a weekend car BUT does see a good bit of racing but isnt a all out race car. also me and my girlfriend also enjoy driving it to the beach every now and then and i dont want a spool to keep me from doing that. when it hits the track again it should be a low 10 sec 1/4 car.
i know i want a moser 9" but trying to figure out what size axles, what differential, & what drag sway bar to use.
i know i want the aluminum center but ive been thinking of a trutrak then i started researching and bob from epp has written numerous times that he would not hesitate to have a spool in a weekend car or even a car taken on long haul trips. <which is what i use the car for. plus i like the fact that its lighter too.
***i know most people who are serious about racing love the wolfe drag sway bars but would they be acceptable for a street/strip combo that sees some beach trips and stuff or would i be better off going with the spohn or bmr drag bars?
***with that stuff said do you think id be ok with a spool?
***i know they have many different splines on the axles to choose from what do you think would be the best for my app?
I'd go with a spool, it won't keep you from driving it to the beach. The only time you will notice the spool is when you turn tight corners.
I'd also go with 35 spline axles, no extra charge with the spool.
Any of the drag bars will work just fine. For $50 Moser will supply and already have welded on the mounts on the rear for the BMR Xtreme anti-roll bar, which saves the hassle. There is still welding for the frame mounted parts for the anti roll bar to be done. Bob
If it's still a street car I'd go with a TruTrac and 31 spline axles--which is what I have. This should meet your performance goals and remain fun to drive. There's a lot of variability as to what's street-worthy though.
I agree with Bob, go with a spool & 35 spline axles for added strength, you really won't notice the spool, just in tight turns, you will however have a very solid 3rd. member with no worries.
from what I've heard the Wolfe piece can break when say on an uneven incline, driveway, etc. theres a few guys here that have done that.
the BMR one is suppose to have a LITTLE articulation.
I wish I would of gone 35 spline spool....so I'd recommend that.
Chad
Chad
is the only one we use. I have it on my '99, the car leaves very even, partly as a result of this anti roll bar. Bob
I hadn't heard of that. The BMR Xtreme http://www.exoticperformanceplus.com....html?item=183
I'll be going w/ the bmr.
Chad
LS1TECH Sponsor
Streetability is most certainly a matter of personal preference. What one guy loves, another guy may hate. I wouldn't have a spool in a car that sees anything more than minimal street duty, especially if there is a chance you might get caught in the rain (ie: beach trip). Would the spool cause a wreck? Probably not. Would a TrueTrac cause a wreck? Absolutely not. Why chance it?
All three drag bars you mentioned will keep the car leaving straight. Is the Wolfe more race oriented? Absolutely. If the Spohn will make the car leave straight - why sacrifice streetability unneccessarily? I don't deal with BMR and have no personal experience with their drag bar, but I know first hand that the Spohn works - see my signature.
Will you break 35 spline axles? No. 33 Spline? No. 31 Spline? No. To achieve maximum performance you should use the smallest axle that will safely handle the torque your car produces. Why run such overkill axles? Check out Moser's Axle recommendations:
http://www.moserengineering.com/Pages/axletech.html
For 90% of cars that see the street even once in a while, the TrueTrac/31 Spline setup is hard to beat.
