Steel d/s and dyno ???? OK, so a local speed shop did not want to dyno my 273 geared car since it has a steel d/s. something along the lines of the tailshaft housing on the trans blowing up due to vibration.... ....long story short, i bought an aluminum d/s and its on the way.....no problems on the dyno once its installed right ??? anyone ??? opinions or experiences ?? |
did you tell them it was steel or did they check |
both, i told them i had the stock d/s for the 273s and they checked and confirmed it |
you should be fine with the aluminum. The dyno cracked my tailhousing with a steel driveshaft. |
Originally Posted by TexasVortexx
(Post 9512334)
you should be fine with the aluminum. The dyno cracked my tailhousing with a steel driveshaft. aluminum one is ordered and on its way !!!:nod: |
© 2024 MH Sub I, LLC dba Internet Brands
