broke u-joint, what to buy now
ok quick question, i just installed my moser 12 bolt last week wne to the track and made 1 pass, as soon as my 200 shot hit the rear u-joint broke. what do i need to buy now? is there a better one out there?, or do i need a better driveshaft?
when u went to the 12 bolt,,did you go to the bigger u joint?
really,,all you need is NAPA part number P447, which is a slightly bigger u joint.
((used to be part number 240-0447))
here is a great write up i just used to get my stocker out to put my new one in for my 12 bolt,,,it was pretty easy.
https://ls1tech.com/forums/gears-axles/878742-u-joint-install.html
if you have already dont all that,,then im not sure what to tell ya.
Being an automatic, that stock driveshaft may hold up, but with nitrous I wouldn't count on it. This is the driveshaft I use and recommend, and it comes with a 1350 U Joint to bolt right up to your Moser rear. Here is a video of my car using this driveshaft. http://www.exoticperformanceplus.com....html?item=541 Bob
