Torsen paddle which way???
Old 10-08-2008, 09:04 PM
mikenews's Avatar
Default Torsen paddle which way???
I just put a new axel is my torsen rearend and I just noticed that the thrust puck or paddle, call it what you want can go in either way. Anyone have a pic of the proper install? It looks like if you put it in one way it will draw up oil when it spins.....
Old 10-08-2008, 09:20 PM
WYATT318MOPAR's Avatar
I have had several apart and even though it will slide in either way I think the retaining bolt will only go in when it faces toward one side..Could be wrong but I have not had a problem yet..If it goes in and the retainer won't flip it over and that is right..Hope that helps you out
Old 10-08-2008, 09:35 PM
mikenews's Avatar
Bolt goes in either way...man this sucks.....lol
Old 10-08-2008, 09:49 PM
here this should help...check out the bottom pic that is looking at it from behind the rearend see the recessed part your talking about...
http://www.torsen.com/files/Installa...20GM%207.6.pdf
Old 10-08-2008, 09:58 PM
mikenews's Avatar
That's it!!! ....thanks!!!!!!!
Old 10-09-2008, 03:46 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
I have always installed them so the slot is picking up oil as the car rolls forward.
