What do you think the new zl1 camaro is going to run,say with drag radials
Once they are out for a bit I am saying 11.8-11.7 on the stock rubber and low 11s on drag radials with mabey a high 10 pass here and there. If you ditch the 20s and go with a 18" drag wheel setup they should have no problem being in the 10s.
I believe GM said if you change the tires you won't gain much if any performance, because the suspension is set up specifically for the goodyear F1s.. whether that's true or not (or if you could retune the suspension for the new tires) remains to be seen.
Not sure, probably .2-.5 seconds slower than the GT500.
Not meaning to be sarcastic, I'm just a little bitter GM hasn't pulled weight out of the Camaro yet and keeps letting Ford one up them.
To put it in perspective Lingefelter did some testing on their version of the ZL1 with the following mods:
The ZL1 that wore the Lingenfelter banner at the track had minimal modifications. The only underhood upgrades was the LPE was outfitted with were a supercharger pulley to bump up the boost, reflashed ECM, 160-degree thermostat and a LPE ported and polished air intake leading to a K&N air filter. The only other modifications to the car were swapping out the street performance tires for skinnies up front and Nitto NT05R drag radials out back. The exhaust was left completely stock which I think was a huge mistake but probably done to keep this away from getting certified for emmissions.
http://www.youtube.com/watch?feature...&v=kUbXWgWas2Q
They ran an 11.2 in this form. So I calculate that with the completely stock ZL1 that you're looking at 11.7's without getting into mods.
Put a full exhaust on this car and 10's are not a problem at all.
