Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
'14 1LE Magnacharger TVS2300 Install
Old 07-23-2015, 06:26 PM
One Bad Z's Avatar
Default '14 1LE Magnacharger TVS2300 Install
So here's what's going on my 2014 SS/1LE ls3 this week. All parts are coming off a 2010 SS ls3.
-Magnuson magnacharger tvs2300 (not the heartbeat) w/1:1 cog drive & will be using 10lb setup.
-JRE tensioner upgrade.
-Kooks headers w/high flow cats.
-BMR trailing arms.
-Street Slayer twin disk clutch.
-MSD boost-a-pump.
-Elite engineering catch can.
Questions:
1) What size injectors come with the magnacharger kit? I've read 52lb & 54lb. Which is it?
2) Do I have to buy a ZR1 3 bar map sensor or will the stock '14 sensor work?
3) My 2014 1LE package already comes with the ZL1 fuel pump, where the 2010 just had the stock ss pump. Am I going to have issues if I don't buy a fuel pump control module? Seen that ADM has one for around $225. I've been told I have to get one, and I've been told I don't need one because tuning can work around it. So which is it?
4) Those with a 2014-2015 and this blower, what did you do about the hood heat extractor? The stock hood vent will not clear the blower. SLP sells a heat extractor to clear their SLP tvs blower but will the SLP vent clear the magnacharger?
Old 10-14-2015, 08:30 PM
beardWS6's Avatar
Sounds like a nice build! Keep us updated on results. I`m thinking of changing from my Stock ZL1 blower myself.
Quick Reply: '14 1LE Magnacharger TVS2300 Install
