Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results!
As promised, we did not waste any time developing parts for the 5th gen Camaro! We have been ready to start the build process in anticipation of our first car arriving. Needless to say, we have been very busy the last two days. The first round of dyno results are with our new TSP 1 7/8" long tube headers and "Rumbler 5" cat-back exhaust system. Keep in mind that ALL NUMBERS PUBLISHED ARE UNTUNED! HP Tuners has not finished their beta software, so we do not expect to be able to tune for another 5 days or so. The car is showing high 11's a/f ratio, so needless to say, there will be some power in leaning it out. I'm sure the timing is set conservatively, too. The tuning will be for another day and another post.
As most have probably seen, our 390-mile SS baselined at 372 RWHP and 372 RWTQ. FYI, the car is a six-speed manual. With the addition of our prototype TSP 1 7/8" long tube headers, off-road connection pipes, and cat-back exhaust, the car gained 26 RWHP and 35 RWTQ to net 398 RWHP and 407 RWTQ! Again, these are untuned numbers. Achieving 400+ RWHP with stock induction will be a walk in the park once it's tuned. We are very pleased with the results. The headers feature 1 7/8" primary tubes with 3" collectors, and the headers will be ceramic-coated inside and out! Our TSP Rumbler 5 cat-back exhaust system will use your choice of two OR four Dynomax bullet mufflers! The system being tested on our car uses the four mufflers, and it has a great sound to it, as you can hear in the video below! Our Rumbler 5 cat-back exhaust system will be a direct bolt-on system just behind the factory cats for those wanting to retain the stock exhaust manifolds and catalytic converters. The great part is that you can start with our Rumbler 5 cat-back exhaust system, and if you decide to add our TSP long tube headers down the road, with or without cats, it will all bolt up! No cutting or welding will be required!
These are preliminary results, and we will complete our results once we can monitor what the PCM is doing. We will also complete our testing of our TSP induction system for the 5th gen once tuning is available. FYI, we will have dyno numbers in a few days testing our Rumbler 5 cat-back exhaust as the only mod, for those interested. Not only will you be able to gain some nice power from the additional flow, but you'll also shed quite a bit of weight! The factory exhaust system is NOT light, particularly the trash cans GM calls mufflers. All said and done, I think it will be very feasible for new Camaro owners to legitimately make 420+ RWHP with bolt-on modifications! We have a few other bolt-on mods in the works that we should be done testing shortly. Give it some time, and you're going to see 500+ RWHP N/A '10 Camaros roaming the streets with heads/cam packages and bolt-on mods! Our new SuperFlow 902 engine dyno will be installed next week, and then we will begin our extensive LS3 and L99 VVT testing. All TSP products will be test-proven, both on our engine and chassis dynos. We will offer proven packages with real-world results for everyone to see. Our second '10 Camaro SS will hopefully be delivered in a month or less, so we will be able to test on multiple cars to guage consistency between vehicles. It will also give us another platform to try other mods! We are dedicated to providing the best parts and packages available with proven results.
Dyno Sheet:
Quick Pics From On The Ground:
Video From Dyno:
http://www.precisionracecomponents.com/2010exhaust.wmv
Video From Startup:
http://www.precisionracecomponents.com/2010exhaust2.wmv
Dyno Sheet:
Video From Dyno:
Video From Startup:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LSxGuy widda 9sec Mustang
I was pretty happy considering it already has duals stock. It's amazing that such a simple bolt-on exhaust can make the LS3 do close to 400rwhp with close to 410rwtq on an otherwise stock engine and induction.
good job guys, untuned with very nice numbers. once its tuned will you guys be taking it to the track? I love that you guys are taking the time to really test out each modification
good jobs keep it up. And the camaro sounds awesome with the exhaust and headers
Thanks for the support guys. We'll be doing more testing the first of the week & then the exhaust has to come off for the production stuff to begin. I'll keep everyone up-to-date & I'll try to keep a camshaft out of it for atleast another week! LOL
Honestly the current plan is to get the long block out of it & on our new engine dyno. From there we can better analyze exactly what camshafts she likes rather than just cutting a camshaft & acting like it's amazing like so many shops do on the forum. Sometimes it takes as many as 20+ camshafts with small changes to find exactly what your looking for!!
I promise we'll get something sweet lined out for you guys!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
What did you guys do with the cat's? Are they just repositioned after the headers, or replaced with aftermarket units? Second question, I have read about how guys with 4th gens would have to modify the ecm - and delete the O2 sensor codes to keep their check engine light off. Is the same thing going to happen with LT's and these changes on this car? I am sure the corvette guys have already been down this road with these engines, anybody know what is necessary?
