NEW PRODUCTS. Bullet Performance Cat Delete
Bullet Performance Gen 6 Cat Delete
Our Chevrolet Camaro Cat-Deletes are an amazing product, one that we are proud to be able to offer to all of you lucky Chevrolet Camaro owners. These Chevrolet Camaro have true performance engines, however the factory primary catalytic converters are very restrictive, killing all chances of true performance, and muting the sound of this engine to simply undesirable levels. This is a Camaro and it should sound like it.
Bullet performance Chevrolet Camaro cat-deletes offer an extremely high flowing design in comparison to stock by removing the primary catalytic converters, while optimizing flow. Many of our competitors reduce the tubing size to 2.5 inch immediately, disrupting the engines ability to relieve its high pressure gasses.
With our cat-deletes all hangers and 02 sensors go to their factory locations so you can guarantee this piece will fit like stock. With this incredible addition you will truly be able to feel the power gains. Throttle response is greatly improved as well as driveability, but you will be most impressed by the sound. Without the primary catalytic converters you can hear the amazing sound of the engine, the same sound that Camaro should have offered in the first place. One ride in a car equipped with this product and it will be very clear to you why so many Chevrolet Camaro owners are going Bullet; It totally changes the character of the car, you will simply love it.
Highlights
3.0" mandrel-bent tubing for optimal airflow and acoustic performance
T-304 Stainless Steel Tubing
Direct bolt-on
TIG Welded and Backpurged
Engineered, designed and manufactured in house at Bullet Performance
BUY NOW
(In case payment was declined: We Use Secured Payment Gateway which might require you to contact you card issuer for approval and payment to go through)
