New Complete Street Performance 2" Headers!
We just announced on our Youtube channel our new 2" Headers with Off Road Connections for the 6th Gen Camaro SS & ZL1.
These headers are a completely custom premium design made for us by StainlessWorks in Ohio.
CSP's New 6th Gen Camaro Headers Feature-
All 304 Stainless Tig Welded Construction
American Made in Streetboro, Ohio by Stainlessworks!
2" Custom Primaries with 3" Ball & Socket Collector with Merge Spike
3" to OEM Connection Off Road Mid Pipes
All Hardware and needed O2 Extensions (We do recommend reusing OEM Gaskets or buying new ones over using the included tube of gasket maker)
What is going to make them so great compared to the rest of the top tier brands? No Trade Offs.
Every top tier manufacturer has some trade off, and I am proud to say, ours do not. Kooks for instance has a great value package, however their header (value package or not) does not fit with the factory spark plug wires. ARH is a great header, however they do not have a value package. And finally Stainless Works, ironically is a problem child which doesn't have a value package, only uses slip fit connections which can make installing tough and then also requires a motor mount removed for install and jacking up of the engine making it even tougher for the average installer.
Our CUSTOM CSP 2" Headers are made to fit without issue, attached is a video of how easy they go in. No removal of motor mounts, no jacking up the engine. They use a ball flare connection instead of slip fit for the header to connection pipe allowing install easier. And the connection pipe connects quickly to the factory exhaust to keep costs down on such a high quality product. Also they fit the factory spark plug wires so no extra hidden parts needed - you wouldn't believe how many header cars came into my shop with a burnt plug wire.
You are getting the best of all worlds with these headers and I'm proud to call them mine. Made for the enthusiast, by the enthusiast.
You can preorder them here-
https://www.cspracing.com/complete-s...v8/csp-camaro/
The Announcement video is here-
