General LSX Automobile Discussion Non-technical LSX related topics.
LQ4 & LQ9, What is the differences between the two
Old 11-04-2008, 07:53 PM
pewter02z28gs's Avatar
i have a stock fbody t56 on 2004 lq9 everything bolts right up and i have an ls6 intake and all the stock fbody acs. as far as ls2 heads go im not sure there quite the same but i have stock ls1 heads on my lq9 to up the comp. to 11:2:1 but other wise a stock interals including cam.
pewter02z28gs is offline
Old 11-05-2008, 10:47 AM
12secSS's Avatar
Originally Posted by Speed Kills
What "crank adapter" are you speaking of with the LQ4?
I put on right in place where an LS1/M6 was with no issues at all. Just remember a pilot bearing........
That is because you were lucky and had a later 2001 and newer LQ4. Although not a good image, it does show the 1999-2000 LQ4 flat flexplate used with the longer crank (adapter) to mate up to the early 4L80 transmissions. The newer 2001+ 6.0Ls used the LS1 flexplate, which is not flat and curves outwards to the trans, to have the torque converter align properly with the trans pump splines.
Originally Posted by 71chevytruck
thank you very much to the guy who posted this thread and to the guy who posted the above information. I have a 2007 60 lq4 and I was getting on tonite to ask a question regarding parts interchange between my engine and ls blocks. If I am understanding correctly I will be able to use parts like intake, heads, water pump,ect. from any ls2 engine. Will I be able to use an earlier model 5 or 6 speed manual like out of out of an 99 or 2000 camaro behind my engine? please post any helpful responses.
You are welcome, and any 1998-2002 Camaro/Firebird V8 trans will work with your 2007 LQ4. The only issue you will have with an LS2 is the cam sensor is in the back-top of the LQ4, where as the LS2 has it on the front timing cover. Also the knock sensors are on the valley cover between the lifters, where as the LS2 has them on each bank, just above the oil pan rail (like TPI, LT1 motors). Otherwise everything bolts up.
12secSS is offline
Old 11-05-2008, 11:20 AM
06BOMGTO's Avatar
Wire harness adaptors are available to install a LS2 into an earlier LS1 application.
06BOMGTO is offline
Old 11-05-2008, 11:43 AM
BlackTA96's Avatar
who makes them?
speartech?
BlackTA96 is offline
Old 11-05-2008, 11:57 AM
12secSS's Avatar
Originally Posted by BlackTA96
who makes them?
speartech?
Most supporting vendors have them or can get them for you. I believe various companies make these adapters like Caspers (IIRC), not just Speartech (nothing against them).
12secSS is offline
Old 11-05-2008, 01:33 PM
06BOMGTO's Avatar
Google is your friend. The ones I saw were Caspers but I'm sure there are more out there.
06BOMGTO is offline
Old 11-08-2008, 11:27 PM
GMCtrk's Avatar
Originally Posted by 12secSS
Wow, a lot of misinformed responses. A quick search would have netted you the correct answer, but to clear the air with facts:
LQ4 and LQ9 are Gen3 engines, not Gen4 (like the LS2, LS3, L76), due to the location of the cam sensor and knock sensors.
LQ4 debuted in 1999
Displacement was/is 6.0L
1999-2000 had iron heads
1999-2000 had a crank adapter to mate the LQ4 with the 4L80 trans (not LS1 compatible)
Compression ratio was 9.5:1
Bloack was Iron
In 2001 the LQ9 was introduced
Both the LQ4 and LQ9 shared the iron block and new 317 heads (similar as the 243, but with larger 76cc chambers), hence both are 6.0L
The LQ9 had 10.4:1 compression ratio, versus the LQ4's 9.5:1
No longer did either 6.0L require the crank adapter for the trans, now works with LSx applications.
In 2004/5 6.0L recieved improved rod design
In 2005 the LS2 block was introduced
It is essentially the LQ9 with an aluminum block
LQ9 still offer with an iron block.
Close. The 99-00 did not have crank adapters, but simply a longer crank that mated with 4l80e, th400, etc. The 99-00 will not bolt to a 4l60e. The 01+ lq4 received a shorter crank that mates directly to a 4l60e, and with a spacer to the 4l80e. LQ9's never came behind anything other than a 60e/65e so you don't have to worry about removing a spacer if you plan on using a 60e tranny. Compression on the LQ9 is 10.08:1. The only differences between the 4 and 9 is beefier rods and flat top pistons in the LQ9. The rods debuted in the 02 LQ9 are the same as LS2 rods. In 05 all lq4s and lq9s received the same internals sans pistons.
GMCtrk is offline
Old 05-11-2009, 06:45 PM
98Camarod's Avatar
What are the cubic inches on the lq4/9 engines?
98Camarod is offline
Old 05-11-2009, 07:02 PM
rice4eatingnotdrivin's Avatar
lq4 = 364
lq9 = 377
rice4eatingnotdrivin is offline
Old 05-11-2009, 07:19 PM
Mike454SS's Avatar
Originally Posted by rice4eatingnotdrivin
lq4 = 364
lq9 = 377
wrong, they're both 364
The other difference I don't see pointed out here but sorta alluded to is the pistons specific difference...not just compression ratio...the LQ9 pistons have floating pins, the LQ4 pistons are pressed into the rods like LS1's. I believe there is also an anti-friction coating on the skirts of the LQ9 pistons that isn't on the LQ4 pistons.
I see a lot of people saying they're having trouble finding LQ9 heads...they're the exact same 317 castings as the LQ4...and they're in BAJILLIONS of pickup trucks, vans and work trucks with the 6.0 liter...I can't go to a junkyard without finding 317 heads...great heads, but not rare at all.
Mike454SS is offline
Old 05-11-2009, 07:41 PM
98Camarod's Avatar
What is the benefit of having a floating pin vice the pressed pin?
Old 05-11-2009, 08:59 PM
  #32
not trying to start **** but pick up a copy of how to build high performance ls1/ls6 v-8's... turn to page 25 and look on the bottom in the red box says exactly what i posted in here... if im wrong oh well but thats just what i read
Old 05-11-2009, 09:30 PM
  #33
Mike454SS's Avatar
must be a typo in the book...or you're looking at specs for a 6.2 liter maybe (I don't know displacement of the new 6.2 in cublc inches)...the LQ4 and LQ9 are both 364 cubic inches, same crank and bore = same displacement...the pistons are different, as I noted...but they're the same diameter
benefit of a floating pin...I don't think I'm qualified to answer that, just pointing out that the LQ9 has them and the LQ4 doesn't...maybe a reputable engine builder will comment on that...I tend to think it's a friction/stress/side loading thing, but like I said, I am not really qualified to answer it
Old 05-11-2009, 09:45 PM
  #34
406malibu's Avatar
if that book does indeed say that, it is a typo. the LS2, LQ4, and LQ9 are all 6.0 L engines, or 364 cubic inches. the differences between the three are the casting material, heads, and compression, not cubic inches.
406malibu is offline
Old 05-11-2009, 09:50 PM
  #35
thank you for clearing that up....
Old 05-11-2009, 09:55 PM
  #36
yup ur right... i looked up the bore and stroke on the blocks and like u said there the same.... sorry for the false information...
Old 06-12-2009, 08:03 PM
  #37
USMCGunner's Avatar
It was just stated above that the heads are the same 317 heads as the LQ4. What gives? Any difference in the PCM tune?
USMCGunner is offline
Old 06-26-2009, 09:28 PM
  #38
Devils Mentor's Avatar
So if running a turbo setup, the LS2 would be the best bet as long as the pistons were swapped for dished?
DM
Devils Mentor is offline
Old 06-27-2009, 07:28 AM
  #39
rdemarce's Avatar
I was always wondering what the difference was between the LQ4/LQ9 myself, and I really didn't find any noticeable differences that would make one better than the other. I have the LQ4 w/317 heads and the FAST 90MM Intake/TB. Only thing is, the compression is higher than most LQ4's (10.3:1). The guy that built it set it up for forced induction.
rdemarce is offline
Old 06-27-2009, 02:54 PM
  #40
10.3:1 is VERY HIGH for FI don't you think?
DM
Quick Reply: LQ4 & LQ9, What is the differences between the two
