General LSX Automobile Discussion Non-technical LSX related topics.
Motor pulled, what else while its out?
Old 07-12-2012, 06:25 PM
johnLs1camaro's Avatar
Default Motor pulled, what else while its out?
I was doing a head swap on my 98 camaro and noticed my pan gasket and rear main are leaking .. so i just decided to pull the Motor to fix those issues and clean the motor. What else should i do to it while its out?
Old 07-12-2012, 06:27 PM
JUSTINSWS6's Avatar
Clean and paibt the motor bay!!!
Old 07-12-2012, 06:28 PM
thompson's Avatar
Go ahead and replace the short block with the updated style block to eliminate the oiling issues of the 98. We can get you into a new short block for as little as $1519. This will keep you from having to go in there again and get you a motor with a warranty. Give us a shout at Thompson Motorsports 972-853-0518.
Old 07-12-2012, 07:14 PM
BLK95-Z's Avatar
While the motor is out you may as well go ahead and fab up a turbo
Old 07-12-2012, 07:25 PM
Good idea, that is something that needs done
Im actually in works of a turbo just waiting on a certain kit. Itll most likely be winter.
Old 07-13-2012, 02:34 PM
NC98Z's Avatar
New Rod bolts.
Old 07-13-2012, 02:40 PM
I worry about the issues people had from switching, i spin the motor at 6800 its been fine
Old 07-13-2012, 03:18 PM
NC98Z's Avatar
I believe the issue came in to play when they replaced them with ARP bolts that required resizing. Katech made some botlts that didn't. I hope your motor stays together for you spinning that high. Mine didn't. The Chevy Vette crate motor I bought to replace it didn't either. Thats how I wound up with a TSP forged 347.
Old 07-13-2012, 03:23 PM
Damn the luck, i did look into katech
Old 07-13-2012, 04:02 PM
mike171562's Avatar
motor mounts?
Old 07-13-2012, 06:02 PM
Already got polys.
Old 07-13-2012, 10:16 PM
hiram007's Avatar
Originally Posted by mike171562
motor mounts?
Thats exactly what I was thinkin but the OP took care of that already
Old 07-14-2012, 07:12 AM
garygnu's Avatar
if you are thinking about a turbo get a aftermarket K-member,it will give you more space for all the exhaust tubing.
Old 07-14-2012, 11:28 PM
sabersaw30's Avatar
Take some weight off the front end.
Old 07-14-2012, 11:31 PM
My6speedZ's Avatar
Do a wire tuck and paint and fill some holes. It is also a great time to do a line lock or ABS delete if it is anywhere on the to do list in the future. K-member is 100 times easier to do with the motor out.
