General LSX Automobile Discussion Non-technical LSX related topics.
Which block to go with???
Old 07-25-2012, 11:08 PM
Raven R1's Avatar
Default Which block to go with???
I have a 6.0 Iron Block, that I purchased from Summitt, then I have a LS 1 5.7 L, that was given to me after I bought the 6.0. It came with 243 heads. Which one would be best for me to use. Putting it in 1967 Impala SS. want lots of power but not wanting to se NOS, no superchgr, just All motor. Just 1 time a month use on the weekend. Sorry, but I am new t all of this. Just want some good advice and input on what to use and not to use. Thanks for all help and advice that are given!!!!!
Old 07-25-2012, 11:28 PM
6898camaross's Avatar
Old 07-25-2012, 11:31 PM
Raven R1's Avatar
What is the highest stroker kit can i go with
Old 07-26-2012, 01:14 AM
usmcpi's Avatar
most stroke an lq4 to 408. You can go bigger like 434 but it's a lot more expensive.
Old 07-26-2012, 01:56 AM
RyanO7's Avatar
Stroked 6.0L and port the 243s.
Old 07-26-2012, 07:14 AM
Raven R1's Avatar
What rotating assembly should I use on the 6.0, and heads and cams with a carb on it, to get 550-600 HP./ Also, what is recommended a 350 turbo or 400 turbo.? Again, I want to thank you for all answers, since I am new to this, I need all advice I can get. Thanks Again!!!
Old 07-26-2012, 11:15 AM
usmcpi's Avatar
I think you have C.A.R.B (California Air Resources Board) mixed up with a carb (carburetor). The heads and come w/ C.A.R.B., not a carb. But it doesnt matter if it has a C.A.R.B. unless you live in smog **** Cali.
Well if you think you will be satisfied w/ 600 HP for a while you can pretty much order any stroker kit as the base/entry level ones are rated to usually rated to 700hp ish. Many vendors sell these for $1800ish w/ either Eagle or Callies products.
Either of the trannies will work fine, however a TH350 offers less parasitic driveline power loss and is lighter. Stock for stock the TH400 is stronger, but you can easily build the TH350 later down the road and still maintain the less power loss. You can't go wrong w/ either but if I had a choice between the 2 at same price Id prolly pick the 350.
Old 07-26-2012, 02:37 PM
RyanO7's Avatar
Where did you get C.A.R.B. from?
He was talking about using a carburetor with the 6.0L and 243 heads.
Old 07-26-2012, 04:50 PM
Raven R1's Avatar
Thank you for the info
Old 07-26-2012, 06:05 PM
usmcpi's Avatar
I dont think so...sometimes u gotta read between the lines
