Looking at 2002 W/ 200K hmmm
Struts and shocks have to be gone at that mileage if they are oem. How are the control arm bushings? Wheel bearings, tie rods, or ball joints have any play? Motor mounts in good condition? Lots of stuff to consider.
low miles cars are usually very nice , high mile highway commuter cars are usually nice and its the ones in between that I try to avoid 75-150k all around drivers see a hard life.
The cars that see regular long distance highway commuting in rust prone areas are usually less rusty underneath also due to all the debris getting vibrated out , all the air driving on dry days drying them out , all the rain rinsing them well on wet days , when I was shopping for my hd pickup everything i was looking at under 100k miles in my budget had scaly frames so I dropped my budget and found one with 130k that the frame was clean on , it has 180k now and stil no rust issues underneath , the tahoe it replaced had 240k and not rusty , never had a valve cover off it 2 trans 1 rear , the 1/2 ton pickup before it had 345k still not rusty and original unopened engine , did blow trans and rear twice each.
beating a dead horse here but I just have had excellent luck with high miles vehicles nobody else wants because they look to close at the odometer and not close enough at everything else
LS1Tech Administrator
Received 1,803 Likes
Perhaps it's different where you live, but with the extensive amount of road chemicals that are used on Chicagoland expressways, the high speed salt spray just gets everywhere and trashes the undercarrige much faster than the cars I've owned for around town driving only. They also seem to mix some gravel in with the road salt on the expressways, so you get that tiny grit hitting the car at high speeds and nicking the paint, thus allowing moisture and salt under the surface. It's like a mini-sand blaster if you're anywhere near a salt truck during a storm.
I had a '96 Bonneville that was my daily driver for many years, all low speed city commuting at first. I did all the oil changes/maintenance myself on this car, so I was underneath it often. Starting in 2005 my commute changed to almost all highway, and within two winters the undercarrige had rusted and corroded more than it did in the previous 8 winters (not to mention the extensive battering that the front end paint took from all the highway driving).
