Improving milage? I got a 2002 camaro ss and I just did my first Mpg check and I got 16.7. Is there any way To get that up or am I stuck with it haha? |
Welcome to the forum! Bolt-ons generally increase mileage when driven conservatively. Internals, stalls, etc....not so much lol. My 99 Z28 A4/2.73 is just a high mile lid/catback car. It gets 30-32 mpg on the hwy and averages 26-27 mpg once my city mileage/beating on it is factored in. That's even a little on the high end from what I've seen on here. If you're stock or near stock like me, lightening your right foot will be the best thing you can do. But to answer your question better you need to give a little more info. Mods, gear, where you drive most, and the like. |
Originally Posted by sawblade99Z
(Post 17394383)
Welcome to the forum! Bolt-ons generally increase mileage when driven conservatively. Internals, stalls, etc....not so much lol. My 99 Z28 A4/2.73 is just a high mile lid/catback car. It gets 30-32 mpg on the hwy and averages 26-27 mpg once my city mileage/beating on it is factored in. That's even a little on the high end from what I've seen on here. If you're stock or near stock like me, lightening your right foot will be the best thing you can do. But to answer your question better you need to give a little more info. Mods, gear, where you drive most, and the like. Just the slp exhaust. It's got 83000 miles |
Is it bonestock? Shifting at low RPMS, tire pressure, clean air filter, clean oil and many others are big factors. I keep my tire pressure at 28-30psi. Just seen its bonestock. |
I remember checking the mileage on my first tank of gas after buying the car LOL talk about disheartening. Don't worry too much. After the new wears off you'll be a little easier on it and the mileage should go up quite a bit. 6-speeds get a couple mpgs better than the autos if driven right...I'm sure you know this. Since you have an SS, you'll either have a 3.42 gear if its a manual, or 3.23 if its an auto. I drive 90% hwy/10% city, so that has a lot to do with my mpg. I think you should expect 13-17 city and 25-30 hwy, depending on the transmission and how hard you are on it. Anyway, drive it for a week or two, try to keep your foot out of it, then report back on what you're getting. In the meantime, do a tuneup. Oil, air filter, clean the MAF, replace the fuel filter, and at least check your plugs. I promise it has everything to do with your driving habits though. Good luck. Edit: And yeah, like blackpanther99 said, tire pressure is a big one too. I normally keep mine around 32 psi. |
Stay stock and perform maintenance on the car. Also, drive conservatively |
(Post 17394445)
I remember checking the mileage on my first tank of gas after buying the car LOL talk about disheartening. Don't worry too much. After the new wears off you'll be a little easier on it and the mileage should go up quite a bit. 6-speeds get a couple mpgs better than the autos if driven right...I'm sure you know this. Since you have an SS, you'll either have a 3.42 gear if its a manual, or 3.23 if its an auto. I drive 90% hwy/10% city, so that has a lot to do with my mpg. I think you should expect 13-17 city and 25-30 hwy, depending on the transmission and how hard you are on it. Anyway, drive it for a week or two, try to keep your foot out of it, then report back on what you're getting. In the meantime, do a tuneup. Oil, air filter, clean the MAF, replace the fuel filter, and at least check your plugs. I promise it has everything to do with your driving habits though. Good luck. Edit: And yeah, like blackpanther99 said, tire pressure is a big one too. I normally keep mine around 32 psi. OP: if you have a M6 I would keep my shift points under 2k RPM. Thats a good thing about a M6 :) If you have a A4 then a professional tuner can also help you gain better MPG. |
What's the best place to get a tune to improve gas mileage if you have a mostly stock A4? Will a tune alone improve it that much? |
Originally Posted by Chief762x39
(Post 17395097)
What's the best place to get a tune to improve gas mileage if you have a mostly stock A4? Will a tune alone improve it that much? As far as the tune goes, it really depends on location. Luckily, there are regional sections at the bottom of the forum here where you can find preferred vendors who are here to tune your car. The best advice I have with selecting a tuner, is make sure you talk to all of the tuners in your area, and go with the one that you are most comfortable with. Obviously I highly suggest a sponsor of this forum, as sponsors like myself take the time to offer as much as possible for LSX powered vehicles. Getting a good tune will improve your average MPG, under the same driving conditions of course! Thanks, Kyle Sierra Speed Shop |
Originally Posted by Sierra Speed Shop
(Post 17395398)
As other stated before, driving like a civic owner makes a huge difference... but like most people, that's hard to do in these cars. :) As far as the tune goes, it really depends on location. Luckily, there are regional sections at the bottom of the forum here where you can find preferred vendors who are here to tune your car. The best advice I have with selecting a tuner, is make sure you talk to all of the tuners in your area, and go with the one that you are most comfortable with. Obviously I highly suggest a sponsor of this forum, as sponsors like myself take the time to offer as much as possible for LSX powered vehicles. Getting a good tune will improve your average MPG, under the same driving conditions of course! Thanks, Kyle Sierra Speed Shop |
Originally Posted by Chaise95
(Post 17394290)
Originally Posted by black_phoenix
(Post 17394550)
Originally Posted by USMC5811
(Post 17399934)
wheres the fun in that?! :-D |
I came out of living with a Scion XB for five years (divorce) when I got my 2000 T/A A4 with 54k mi. I was shocked that I only get about 15mpg. I tried to drive like a hypermiler Prius earth biscuit for a tank to see if there was an improvement. I made it through about half the tank and said f@ck it I didn't by this thing to save gas. It seems no matter what I do I get a constant 15 mpg so I drive it like I want too. |
My 2000 BMW 540i with a stock LS1/T56 combo only got 20mpg on the freeway but it did have an awful 2.82 gear. |
go to ecomodder.com and maybe those guys in the forum can help you out. a few years ago i tried to get better gas mileage and i got 21.43mpg out of a 99 SS auto (with just lid, catback and a tune i think). when i got the stall i lost about 4mpg. http://ecomodder.com/forum/fe-graphs/sig632a.png http://ecomodder.com/forum/fe-graphs/graph632.gif |
© 2024 MH Sub I, LLC dba Internet Brands
