Wrecked Camaro vs already pulled LS3?
I am debating on if I want rebuild the LS1 in my TA or get an LS3???
The reason behind the title is that I have found it dang near cheaper to buy a wrecked Camaro than buying a used LS3 flat out. I just your guys feed back pros and cons before I make TOO BIG of a decision.
If I do rebuild the LS1 I will more than likely boost it..
Just need some feedback.. Thank you!!
I hear this thrown around here and there on this sight and am unsure what it means..
Will I still have to switch that even if I use the harness on the motor is it better to use the one for the LS1??
