8.1 swap?
The 8.1 isn't a part of the LS family, The 8.1 is a 496 Big Block with EFI that is the GEN1 block redesigned with different features but has more in common with the GEN1 then the GEN3/4 LS family.
The 8.1L as said above isn't a LS motor, and it's also expensive and has limited aftermarket support when compared to a LS motor or a earlier more traditional BBC. If you want a 496 (8.1L) you would be better off just starting with a standard 454 and having it rebuilt with a stroker kit and add aftermarket EFI to it.
