Aeroforce interceptor gauge
Its essentially a really cool looking obd2 scanner. You can get a scanner that will do the same thing and maybe a little more for less than half the price.
If you need to check all your stats while driving, then yeah, the gauge will show you as you drive, but if you can wait to park and connect the scanner, you can save yourself some cash.
That being said, I used to have an Aeroforce Interceptor gauge on my z28, and it was pretty cool. It showed me timing, misfires, true rpms, and much more while driving. However I sold it when I sold my car. Now that I have another fbody, I bought a handheld scanner instead.
thanks guys, im on the fence with it still, i like it with all the options that i can set it for and view.
does anyone know if Aeroforce displays trans temp? is it accurate enough? going to be running a stall soon, if it does not i will just run regular gauge.
as for a hand held scanner i have a friend who owns a shop and can use his scanners when needed.
go fast parts are done for this season... maybe! i have had the car for like a month, suspension is next and needed.
Yes it reads trans temp. And from what i could tell, it was very accurate. I double checked a bunch of parameters with other scanners and they were all almost identical from what i remember. They even have a great customer service team so you know youre covered.
