Share you NA build cost $$$
#44
Aw heck...
TSP Darton 454, PRC 285s, "near turnkey" longblock with most parts, mostly TSP in house upgraded internals (aka not the high $ race parts) - $14K
MSD intake, Holley TB, injectors, fuel rail - $2155
Miscellaneous stuff, new starter, w/p, intake parts, etc - ~$2K
All in all wasn't that bad, actually budgeted 20K and spent about that all said and done.
I'm more bitter about the $3500 I paid for a cam install back in early '02 when I took it to a hick shop and they yanked the motor and turned a 4hr job into a two week one. But it motivated me to learn how to do (most) of my own work.
#45
The new 418 rebuild that I'm going through at the moment is about $6500 in new parts between the lid/front cover and the rear main cover, re-using old heads, rockers, intake & exhaust. Sunk in about $13K since late 2017 on tires/wheels/suspension/steering. Clutch is coming up I'm sure, some AP Racing brakes, and larger headers too. If I was crazy, I would have bought the Cortex front SLA kit.
#46
Can't risk scaring away the NA builds otherwise we won't have much to talk about in the Gen III engine forum
On don't worry my next NA build a 402 in the planning...
Used LS2 block $800
Used GMPP 243 heads $1,200
Fixing all the issues with used heads to make me happy $800
Summit upgraded LS1 rockers $200
New Mamo ported LSXR intake for the heads $1,450
Being me dumb enough to share the cost and my mistake with buying heads that need several little issues fixed - priceless
Used LS2 block $800
#50
1951 Desoto wagon build
$1400 for low mileage Gen IV truck 5.3 with VVT and DOD deleted and a “thinned harness”
$600 for new harness, because the previously mentioned harness wasn’t even for a Gen IV
$200 for accessory brackets
$650 for custom headers
$900 for CTSV T56
$200 for Sonnax yoke adapter
$600 for my 4 link kit
$200 for disc brake conversion adapters
$650 for Vintage Air kit
$200 for AC compressor and plumbing
$1100 air bag kit
$200 generic auto electrical harness
How much for my time for researching all of this? HAAHAA. God I hope my wife never reads this thread....
#54
Forgot about this thread...it’s over here in no-mans land. No offense meant by that of course.
Used LS2 block $600
RED Darton sleeve install $2150
Rotating assembly 434” $2400
Mamo package including loaded MMS 265’s, ported MSD, custom solid roller, ISKY solid lifters, ARP headbolts, ATI 10% UD damper, NW 102, ARP damper bolt, custom Manton pushrods, head gaskets, injectors, LS7 fuel rail, YT rockers, ported Melling oil pump $14k+
Holley pan $300
Front, rear, valley covers $250
Windage tray $100
ARP Main studs $215
ARP bolts throughout $200
Billet timing set $150
Katech billet main caps $500
Machine work for final hone, fitting billet main caps/align hone, and misc. stuff $1400
2” ARH headers $1400
Walbro 450 $100
Return fuel line and fittings/regulator $250
Associated other costs...
RPS BC2 clutch used $800...not part of engine build, but required, trust me
I needed an oil cooler so I went with an Improved Racing MHX-520 and lines/fittings/thermostat $800
Katech valve covers, slotted, with custom engraving done by another shop, coil relocation brackets, and wires $1100
Fluids add up quick, especially oil
Put 40 miles on it, and tore it back down for re-ring and crank polish. So there’s another ring set, custom Cometic headgaskets, bearings, and fluids, etc..
So...I was at $24,715 just engine, but there’s some shipping costs for block that I didn’t mention, and then another $2700 for clutch, oil cooler, and valve covers. Fluids add up quick. Probably have $300 in just oil, but I run Gibbs LS30. And I’m sure I’ve missed something here. I’ve got $1000 in tuning from Vengeance and it still needs work, that I didn’t mention. And now that it will spin to 7500-7700 on up shifts, I need a trans that will actually shift, so I’ve got a new Tremec T56 MagnumF in the works, so there’s another $3400...Geesh..no wonder my wife is pissed.
Used LS2 block $600
Holley pan $300
Windage tray $100
ARP Main studs $215
Walbro 450 $100
#56
Pick your poison!
Over $16,000 tied up in my LSX build and its one of those addictions that make $100 bills disappear but hey at least I have something to show for it.
#57
Dart LS next block : 2637
Callies Dragon Slayer Crank : 1800
Callies ulta H-beam Rods : 1400
AFR 245 Heads with custom work and all Titainium parts : 4500
Jessel Shaft Rockers : 1500
Custom MLS head gaskets : 300
Custom Diamond Gas ported pistons wH13 Wrist Pins : 1550
Custom .904 Lifters with needle-less bronze bushings : 1025
Rod bearings : 152
Main Bearings : 197
Custom Comp Cam : 637
Rings : 142
!/2" head stud kit : 450
Machining for oversized lifters : 198
Ls next parts kit : 138
Drill and tap for 1/2" head studs : 221
Block prep : 500
Balance Rotating assembly : 240
Degree cam : 100
Check piston to valve : 50
Fit rings : 100
Assemble Engine : 750
Set up Jessel Rockers : 100
Billet Double Row Timing Set :162
Melling oil pump : 120
Trend 3/8ths Push Rods :120
Milodon oil pan and pick up : 320
Moroso 55 gal electric water pump : 385
Billet Valve covers : 750
Msd coils : 738
Fire Core wires : 135
Cid LS3 Intake : 1000
Custom Pro Systems 1100 Dominator : 1000
Kooks 2" headers 1000
ICT Billet adaptors to mate the LS3 Cid intake to Catheadral port heads : 200
Edelbrock 2 piece timing cover : 262
Wilson 2" 4 hole 4500 tapered spacer : 225
Motor is set up and handles 400 in spray no sweat. But that is a whole other list. Lol
Rod bearings : 152
Main Bearings : 197
Rings : 142
Block prep : 500
Degree cam : 100
Fit rings : 100
Msd coils : 738
#60
