Leaking water into passenger floorboards...HELP
When it rains water runs down and pools into my passenger side floorboard.
Im about 99% positive that its because when i ran my nitrous feed lines and electrical wires i removed the grommet in the firewall to access the engine bay from the interior.
No i don't have the grommet anymore and i didn't have this problem until i removed it. What should i do? Should i run silicone sealer in the hole? or try to divert the water from running there in the first place?
help!! i don't wanna have to replace my floorboards anytime soon.
wow it might be ur nitrous issue, when my car did this it was because the drain was clogged under the car that let the A/C water drip to the floor. Has this just started happening or has it been a while. Have your tried running your AC on full blast and seeing if the water streams down.
I have never noticed it with the AC on, it seem to only happen if my car sits in the rain for a while. If i drive through rain it doesn't seem to. Its like it has to run down the windshield and down into that area below my computer, then into my interior.
A buddy of mine had water leaking into his Equinox(dont worry only his DD haha, he's got a C6 Vette) and didn't realize it for awhile. Then it started to smell really bad and the dealer finally found he had water leaking in under his carpet.
