How much HP to lift front tires???
Ok, I know first to do this, you need travtion, but once you have the traction, how much HP does it require, on average, to lift the front wheels? I know it depends on the weight of the car too, but there's gotta be an average!!! And, I'm not talking about wheelstanding, just about 1' off the ground!
There are cars that have done it with less than 400. They just need to be set up properly. I believe lifting the wheels it more dependant on the susp./tire setup than sheer power. Mainly because there are 700hp cars that can't lift the tires to save their lives, they can't harness the power, they just spin.
But givin the right set-up i think one can safely assume it will happen almost everytime with cars in the 450-500hp range.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
QA1 R's up front , 4000-4400 Converter, 15" or 16" ET Streets or better, Remove the front sway bar, Throw in some 15X3.5 skinnies just for the hell of it and you will have lift off!!!
It's all about Weight transfer
I have 325rwhp and lift mine about 3". My suspension is set up very well and I hook very well. It doesnt take alot of HP but as stated suspension and a good tire, and a 4k conv doersnt hurt
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
And get as much weight as you can off the nose of the car. Remove the front crash bar, foglights, washer fluid reservoir, relocate the battery, run skinnies, and remove swaybar of course. All of that stuff is 6-8 ft from the rear axle, and the further a weight is away from the center of motion, the harder it is to lift it.
All the little piddly weight stuff (like foglights) does add up when you go crazy with weight reduction.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
