Clunking noise comming from under the center console & shifter...what is it??? Yesterday me and my girlfriend were in my car (01 Trans-Am WS6), we were crusing on the highway heading home from a day out, when all of a sudden we hear this loud clunking noise comming from under the center console/shifter. It felt like something was hitting the bottom of the console, and you could feel the bump if your arm was leaning on it. I pulled over and looked under the car, I was on the side of the highway so I coulden't get a good look, just saw that nothing was dangling or leaking. I also noticed it did this noise when I hit the brakes, not slamming on them, just regularly hitting them to slow. Sounds like something is loose under the car. So I continued the drive on home, then driving it today to work it was doing the same thing, sometimes when I let off the gas and get back on it clunks, other times when I hit the brakes and let off it clunks, and also I was NOT beating on the car AT ALL when I first started hearing the sounds, I was honestly crusing at 70MPH in 6th gear on the highway...one of the rare times I can honestly say that lol. It does not feel like a transmission or clutch problem, every gear still worked fine with no grinds or popping out, also clutch felt fine and shifting was fine. Today when I got home from work I called a friend over to take a look under the car...at first I thought the driveshaft may be loose somehow, then we thought a transmission mount, and also possibly a U-Joint. We got under the car and looked, mind you this is just jacked up in my driveway so we didn't get a real good look at it, but from what we saw the driveshaft is fine, the transmount looks fine, and the U-Joint also looks alright and is not leaking or anything. Tomm I plan on bringing it to a shop with a lift, but I figured I'd post it on here to see if its a common problem and maybe someone can help me out prior to it. Thanks and if you need more info just ask. |
I had similar symptoms before on my last TA. found a loose bolt in a lower control arm. |
Anyone else? |
I would also check your tranny mount because it seems like it may be broken. Check your LCAs like someone else said as well. |
Originally Posted by CranMaro99
(Post 9697855)
I would also check your tranny mount because it seems like it may be broken. Check your LCAs like someone else said as well. i had the same problem. tranny was hitting the trans tunnel. fixed it with a $20 autozone mount. |
It was the tranny mount on my 88 Formula when I had that noise. |
Alright so it seems like either a tranny mount or something with the LCA. Thanks alot guys for the help! |
I'd bet it's the TA mount. I had the bolt come off once and it made the exact same noise under braking/accelaration. It sounds like if someone was hitting the center console with a bat from the bottom. |
Originally Posted by SS#2906
(Post 9698777)
(Post 9698777)
I'd bet it's the TA mount. I had the bolt come off once and it made the exact same noise under braking/accelaration. It sounds like if someone was hitting the center console with a bat from the bottom. You were exactly right....the bolt popped out of the torque arm mount...its all better now though! Thanks everyone for the help! |
Originally Posted by 01 Trans-Am WS6
(Post 9699692)
mine backed out too. all of the sudden one day, was prolly loose for a while. |
Shit is on there TIGHT now so hopefully it will be good from now on...but if not I know what the problem is |
hope it works out. I cant come up with anything else but the TA mount or the trans mount |
[QUOTE=01 Trans-Am WS6;9699692]You were exactly right....the bolt popped out of the torque arm mount...its all better now though! Thanks everyone for the help![/QUOTE Did u have to replace the mount are the bolt ? |
(Post 9696084)
Another reason to shit can the stock torque arm. |
Originally Posted by qweedqwag
(Post 20066475)
© 2024 MH Sub I, LLC dba Internet Brands
