SIR coil
After you pull the steering where there is a snap ring holding the coil in place. Then you pry it out. There should be a wavy copper washer under that.
Then you should be able to fish the wiring out. If you need to you might have to remove the locking ring. I can't remember if you need the remove it for space concerns.
Removing the locking ring makes it a little bit harder.
Sorry for all these questions...
To remove the locking plate you have to buy a 10 dollar removal tool which compresses the bearing preload spring. You would see a small ring exposed by a couple of mm. Spread that ring and snake it up the upper column shaft.
