Did a sea foam top end cleaning but not alot of smoke.
I pulled the big vacuum line off the brake booster and I poured sea foam down it and it produced lil to no smoke at all and I dont know why. Car seems to be running better thought now. I also poured a full can into the tank. Why would it produce so little smoke? I know from experience that a top end cleaning produces alot of white smoke.
Mine smoked a lot for the first 15 seconds, lol. Really, so much I couldn't see my house, or inch infront of me, crazy. Then, not much at all, wasn't sure what I did wrong, but it seamed to run better.
Here what I did to get mine 100 % clean.
Took off TB, had it ported(lol) cleaned and polished it.
Cleaned the inside with a microfiber cloth and carb cleaner.
Changed the PCV valve
Let it run and get up to temp.
Poured into brake booster (1/2 can)
Had friend shut it off while pouring and let it set for 15ish minutes
Started and let it get warm and did a lot of WOT runs.
Poured 1/2 can in 1/2 tank of gas.
No smoke. Idle drastically improved, especially while hot and in gear.
My car smoked a little for about 10 seconds but i think you missed the part where you spray sea foam in the intake and let it seat for 10 to 15 min. Try that
