security light on?!?!
my security light has been on since i got the car and i have know idea y.
my alarm works and keys are fine. idk if it can do with the radio being changed but idk what else it can be
has anyone had this problem???
It's probably in "fault enable mode".
If the light is still on somethings still wrong - the correct nominal resistor(s) should turn the security light off.
Light should come on for a bulb check, then go off if working properly. Here's a basic VATS diagram: http://shbox.com/1/vats_bypass.jpg Fault enable mode means the malfunction happened after the car was started, so sees a problem, and not someone trying to steal the car.
