Turn signal doesn't work... I have a 2000 z28 and the right turn signal stopped working. When I hit the turn signal lever, the right arrow just stays green on the dash, the front right turn signal doesn't turn on, but the rear one stays lit until I unclick it off. Checked bulbs, all work. I can put the hazards on, and then the turn signals work perfectly. I'm thinking that the lever might be messed up? I had installed halo head lights a while ago, and tapped into the running lights, so not sure if there is something going on with that now. I shook all the wires around a lot, moved everything around real good, and there doesn't seem to be a short or anything that I could find. Has anyone had a problem like this before? Thanks. |
when you checked the bulb did you pull it out and check for water or corrosion in the socket? very common problem from what you described. |
Originally Posted by 98TAjwh
(Post 10956928)
the exact thing just happened to me yesterday, put the right signal on and it would stay green. I changed the bulb same thing, so i bought a new flasher, but before i changed the flasher i double checked and i put the bulb in backwards. I would just change the bigger bulb |
Originally Posted by 93cz28
(Post 10956935)
x2 same thing happend with mine. clean out the socket |
Awesome, I'll check out the socket. Did u just pick one up at the gm dealership, or did u order one online? Haven't checked prices yet and didn't know if there was a big difference. |
Originally Posted by matrik
(Post 10958925)
(Post 10958925)
(Post 10959636)
depending on the extent of the corrosion, you should just be able to clean the socket out and replace the bulb. i recommend ordering a new light housing to keep water from getting back in. cost you about $30. if the socket is beyond repair you can get a generic one from the vato-zone or order one online for around another $30. i think you'll have to do some jerry rigging on the auto-zone one though. |
| All times are GMT -5. The time now is 12:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
