Sponsored by: CARiD
spring
Old Feb 8, 2009 | 09:29 PM
lss1love's Avatar
Default spring
I found a broken spring on the floor under driver side dash. I assuming its from a pedal possibliy the clutch? All the pedals still seem to work fine.
Car has 33.5k miles on it.
any help would be great thanks
Tadd
ps. yes its a M6
Old Feb 8, 2009 | 10:01 PM
SparkyJJO's Avatar
pic of spring?
Old Feb 8, 2009 | 10:04 PM
wssix99's Avatar
Save the manuals!
Clutch pedal spring. They are notorious and have lasted me only 30K before they explode. They have a coil and then 2 attachment points on either side of the spring. Often, one of the attachment "legs" breaks off. You may have half of the spring off and the other "half" still attached to the pedal.
The spring isn't needed but your pedal will feel a little floppy without it. If you have higher mileage and are going to replace the spring, you may also want to replace the white plastic bushings that the spring sets in. (As they age, they tend to squeak a little bit.)
Also, if you do replace the spring - be prepared to spend a couple hours on it your first time. Its a real bitch. Once you take off the IP cover, you need to get under the dash and then need to reach "up" with long pliers to get the new one in place.
Old Feb 8, 2009 | 11:22 PM
lss1love's Avatar
oh great, is it safe to drive it? i dont wanna get stranded anywhere
Old Feb 9, 2009 | 11:00 AM
hj99Z's Avatar
Yeah it should be fine. I removed the spring on mine because it gives a better pedal feel.
Old Feb 9, 2009 | 03:19 PM
wssix99's Avatar
Save the manuals!
sure. the main drawback is that the pedal will be a little "off" in its palcement when you are off of it and it will have a different feel than it did before
Old Feb 9, 2009 | 04:12 PM
lss1love's Avatar
ok cool, cause its 70 here in atl today
Old Feb 13, 2009 | 11:02 PM
C-Sicz's Avatar
Yes, its a clutch assist spring. My snapped in my C6 and I replaced it with one from a C5 b/c I heard they were more durable.
